Displays statistics for of the Web server target.
target | Specifies an alpha numeric string that identifies the configured target. |
N/A.
Use this command to display the connection status, enable status and event statistics of the Web server target. If a target is not specified, all configured targets are displayed.
The following command displays statistics for all of the configured targets:
show xml-notification statistics
The following is sample output from this command:
Target Name : epi Server URL : http://10.255.129.22:8080/xos/webservice Server Queue Size : 100 Enabled : yes Connection Status : connected Events Received : 450 Connection Failures : 0 Events Sent Success : 450 Events Sent Fail : 0 Events Dropped : 0 Target Name : epi Server URL : http://10.255.59.6:8080/xos/webservice Server Queue Size : 100 Enabled : yes Connection Status : fail Events Received : 31 Connection Failures : 3 Events Sent Success : 2 Events Sent Fail : 29 Events Dropped : 0
This command was first available in ExtremeXOS 12.4.
